Disc Brake Upgrade?
Fast GN
I am wanting to upgrade to 4 wheel disc brakes. I am running 17" wheels. What is my best option with out spending a fortune. I would like to have cross drilled and slotted rotors in the front. Thanks in advance.
Dont get drilled rotors, they will crack if you really abuse them. Powerslots with Hawk pads are good. I would also go with the B body front brake swap. Not sure about the back, try doing a search.
The brackets in that kit can be bought for less than $100 from smileys and the rest of the parts are over the counter from any parts store. Use the rotors from an F body and the calipers off a mid 80 firechicken. Every thing is pretty much a no brainer. I'll be using last gen camaro disc set up but you have to cut and drill the mount to fit it.
