SignUp Now!Any reason you're stuck on the Caprice brakes? Camaro LS1 brakes, pretty straightforward installation with great results.
Can you run a 15" wheel with the camaro rears? As far a I know all you need is an adapter plate and all the parts from the rear brakes of the camaro. Hopefully someone will jump in and either confirm or deny my statement. Also do they allow for use of the e-brake? If there is a broken down thread of it that would be appreciated. Charlie I know you did it but it didn't really go in to this bolts to that and so on. Thanks
Just did this on my car. Here's some pics for ya.:biggrin:
anybody have a link? ls1 rear brakes would probably be the easiest thing for me to find since I can't find anything else locally
I could be wrong but I think those are t-type wheels and thats the last gen blazer setup. Charlie did you have to do any mods to use that setup or is it basically a direct bolt on?
What wheels are those? Looks reallll close
Aren't those the front drive 80s eldo rear disc brakes? Those Eldos came with 15" wheels, so I'd think that vintage disc brake will work with 15s.
