You can get ring terminals with star washers at Grainger.
I just found this article stating that GM does not recommend a star washer on chassis or body grounds...interesting...wonder what John Spina thinks of this.
Document ID# 1581142
Subject: All General Motors Passenger Cars, Trucks and Utilities Use of Star Washer on a Body or Chassis Ground - kw wire connector terminal starwasher star washer #PIT3353 - (01/07/2005)
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in the PI.
Condition/Concern:
Use of a star washer under a ground wire connection. In the past, it has been known to use star washers under most ground connections.
It was believed using a star washer would improve continuity to ground and prevent the ground fastener from becoming loose. With vehicles built today, star washers are not being used under any ground connection.
It has been proven by GM engineering that with a star washer installed, it will increase the chance for corrosion and prevent the terminal from achieving proper torque.
Recommendation/Instructions:
It is recommend NOT to use a star washer on any ground connection to the body or chassis of the vehicle.
Bryan
