- Nov 24, 2001
Here goes..... So ive got some extra pieces and parts lying around from various kits and DIY kits from the past.
Found:
New GM overflow bottle
Sureflow 60psi pump i purchased about 4 years ago w/ -4 JIC fitting
Brass Inline check valve
SS feed line from pump to m-10 fitting in up pipe 1/8th brass fittings
SMC non progressive controller
So the almighty question is this, if i wire up the smc controller to the 60psi pump while using the sureflow 60psi pressure switch, the pump will cycle on and off correct?/// while the controller is still feeding voltage to the switch?
If i turn the SMC controller down, will it have enough voltage to close the switch for the pump to come on?
I am running 112 octane and 21psi with 25° of timing in 3rd gear.
Fuel pressure is 47 and my millivolts at 110+MPH are 710 to 699
Yes the stock injectors are maxed out power wise, i have a race this coming saturday and need just a tad bit more fueling for all gears.
So if i set the controller to low flow, and spray on point to 18+psi, then the car should have enough fueling to take the boost up 2-3 more psi.
As of now, this kit is temporary till i can retune with the 009s, but if i get great results, im aint touchin it!
Cliff notes:
SMC controller work with sureflow pump?
Anyone sell m-5 hago fittings?
Other than methanol, am i missing anything?
Out $2.51 in fittings this morning at tompkins
:biggrin:
BW
Found:
Cliff notes:
BW
