Ok here's simple one that's easy to do. After putting the 10mm wires on my car I couldn't find wire looms and the stockers wouldn't fit. So I made my own using 5 zip ties.
I used color for this demonstration but the ones on the car are all black.
Place the wires together and make one loop around all wires
Then wrap a loop around the main loop one between each wire.
Pull the loops right and then pull the main loop tight
Trim the ends and you're done.
