DIY Wire Looms
aminga
Chicks Dig the powerbulge
Ok here's simple one that's easy to do. After putting the 10mm wires on my car I couldn't find wire looms and the stockers wouldn't fit. So I made my own using 5 zip ties.
I used color for this demonstration but the ones on the car are all black.
Place the wires together and make one loop around all wires
Then wrap a loop around the main loop one between each wire.
Pull the loops right and then pull the main loop tight
Trim the ends and you're done.
That's an old Nascar trick.......I've been doing it for years.
