m233roller
Banned
- Jan 25, 2002
Ok, who can tell me if theyv'e had any rear main seal leaking problems with DLS's BA cranks with NO seal knurling done to them ?? Thanks Mike
SignUp Now!The problem was on the 109 stroker kits using a non knurled crank.BA CRANK. DO A SEARCH USEING KNURLING ,,,KNURLED CRANK ,,,,,,REAR MAIN SEAL LEAK and you will find some some info.
Sorry guys,
I should have been alittle more pacific. This is for a 109 block, stock stroke DLS BA crank. I know about the Stage 11 stuff.
Just a question, but if the knurling was not needed on the crank of a 109 engine, then why did GM put it on the stock crank in the first place? If it only needed a better rear seal, I would think that it would have been cheaper for GM to have a different seal manufactured than the machine work on the stock crank.
By the way, my engine built by Weber has knurling on the stroker crank.
stock stroke or stroker 109 it still needs to be knurled..hate to sink your ship,,,,,I burnt out 4 rear main seal kits (Overheated)due to lack of lines machined on surface of crank where seal rides....these lines hold some oil for lubrication and also due to angle of lines pitch oil back in towards motor.
