87-TURBO-T
 - Apr 16, 2009
curious to see who is running the DLS pump, and what kind of preasure are you running at hot idle? thanks
SignUp Now!The pump is not going to be what regulates the pressure at hot idle.
guess what I mean to say is it has 25-30 psi hot, step on the gas goes to 90psi. Is it too much? It does have an adjuster on it.
Id want around 12-15psi per 1k rpm.guess what I mean to say is it has 25-30 psi hot, step on the gas goes to 90psi. Is it too much? It does have an adjuster on it.
fresh VR1 20w50
how many rpms is it hitting 90psi? Could be just from the oil being fresh?
