lilthumper
In front of your regal
- Jun 20, 2001
Whenever I have seen an 02 go bad, I have seen it not correct at all and show 15.99 actual AF. Well, after putting my car back together last night with the new plugs and wires, the car had the same problem. I had the correction turned off and the actual AF was reading 11.00--13.00 during the episode, usually in the 12.XX range. I then turned correction on with my targets set at 12.5 and the damn thing started adding +25% correction. So I turned correction off again and decided to ignore the ACTUAL AF reading of 12.XX. I pulled OUT 15 in the VE map and my car suddenly was now missing at 6000-6300 rpm!! It has been missing at 4800--5300 this whole time. I had to pull it in the garage after that because I was waking the neighbors. Is my 02 wacky or what?
