Eric Stage I
TurboTweak Guy
- May 25, 2001
Can I get away with running 93 as long as I don't boost it or do I need a 93 chip. Trying to figure what I need if I run across a situtation where I can't get E-85 on a trip.
In an emergency, no problem. As soon as you start the car up on 93, and it goes back into closed loop, the BLM and INT correction will automatically pull fuel out. No adjustments necessary. It will be rich for a minute at first, but the chip can automatically pull the full 30% back out based on the stock O2 readings. It won't be perfect, but you can drive it around fine. Even up in boost, it will just be rich, but if you have the wideband correction enabled in the 6.1 chip, it will lean it out automatically. It's best to stay out of boost though until you get right tune back in.
Regards,
Eric
