shocker998md
- Jan 8, 2009
Alright guys I've hit a little bit of a wall. At one time, 5 years ago I tore down my bottom end while doing a rear main seal. Two of the rod caps got out of order, as in turned around, they are still on the right cylinder.
I'm working on assembling the rods to measure for oil clearences. On the piston I have the foward facing dot, the rods were never removed from the pistons, the tang of the bearings I've read are supposed to face out to the header. And then I did the same with the cap, tang towards the header. Does this look correct?
