SignUp Now!there are several facets to the question of oil life and in a short post i really can't begin to cover it all but i'll get you on the right track------oil designed for cars like most things except for rocks really can't really last forever but the conditions it is stored in can make a lot of difference------lets start with the base oil-------base oil types 1 and 2 (conventional) cannot last as long as type 3 (severely hydrocracked conventional sometimes marketed as "synthetic") and type 3 cannot last as long as type 4 synthetic------all base oil has somewhat lighter components that tend to evaporate before the heaver components and when that happens the base oil quality is compromised-------what causes evaporation????? heat and or storage in open containers would be the worst offenders------storage in lower temps and good quality sealed containers would surely make most BASE oils outlast you and your car-------HOWEVER motor oils are not just base oils and the better ones contain up to as much as 20% additives------addditives are another issue entirely-------while most additives are relatively stable it is probably safe to say that they would interact or breakdown much faster than any base oil------just how quick that might be still seems to be a pretty long time as long as the storage conditions are reasonable-------i have tested sealed cans of oil that are in excess of 10, 20 and even 30 years old and they seem to meet specs current at the time of their manufacture for additive percentages and viscosity--------there could be certain combinations of additives that could result in chemical instability but i personally haven't come across any in a lot of testing--------since motor oil these days is better overall than it has ever been there seems to be no reason to doubt that it will not have a rather long shelf life---------now what about "less than ideal storage"??????-------as soon as you open the bottle the degradation begins but its really slow-----pour it in your engine and time speeds up like you can't believe------interaction of the additives with different metals in your engine and even minute gasoline blowby remnants make the old "once a year" whether you drive it or not really good advice-------drive it once or twice for a short trip where it doesn't warm up completely and a destructive unstoppable chain reaction starts to degrade your oil and creat rust and deposits inside your engine-------byproducts of combustion create acids that really degrade your oil-------good grade oil can last a really long time if the engine is always brought to temperature and used regularly-------this of course is tempered by the condition of the engine-------oil lasts much longer in good engines as opposed to worn or poorly tuned ones--------short story???don't worry about oil on the shelf------its just fine------its the oil in your engine that is going bad--------of course you could always consider that the oil companies are changing their specifications every couple years-------current is SM-------GN's came out under SF--------technically that would make all your old oil "no longer current" -------does that make it "no good"-----not unless you have a new car-------i for one sure wish i had salted away a couple dozen barrels of old SG oil when it was available and cheap................RCI've heard thru the grape vine that motor oil has a shelf life. Any truth to this? Or is it a myth?
If it has been on the shelf for several years you need to shake it up because the additives will seperate and settle on the bottom of the bottle.
good quality oils contain additives that are in what is know as "chemical suspension"-------a rather complex condition to descibe but similar to salt in seawater or flavor in a pepsi-------below a certain percentage it takes quite a bit of "processing" to remove it from the base liquid-------i would NEVER consider any motor oil that required "shaking" before use after any amount of sitting on a shelf--------it will surely seperate under elevated temperatures and pressure creating sludge and/or clog your filter--------it would be a BAD choice--------if you have reason to suspect this of your oil (i don't think its possible with a quality brand name API rated oil) you should put some of it in a clear container and let it set for a while-------if it seperates at all you should seperate it forever from your car...............RC
If you have a New bottle of oil and it sits on the shelf for 3 or 4 years the Additives in that oil WILL settle to the bottom. I have seen in several quality brands of oil. I doesn't mean the oil has gone bad, it's just settled! The additives will eventually fall out of suspension, its a fact. So to be safe i shake the oil a few times before put the oil in the engine. I prefer shaken not stirred. lol
