DOH!!!, what am i missing guys? GN1 dp to TE60
reconfox
First post:tongue: and tryed the search no luck. Anywho, i recently bought the GN1 stlyle downpipe and a TE60 TURBO because I have decided to start modifying the car before I deploy AGAIN:mad:. PROBLEM: where does the hd actuator connect to this type downpipe? and the flange from the dp to the turbo is it missing a hole for the flapper? thxs
I just looked at their website and they don't have a internal wastegate model listed, just external and no wastegate (which I guess you have). The reason for this style DP would be for someone that's going to install a external wastegate in the header instead off the turbo housing.
I do not believe they sell a DP for what you need.
Which picture does the one you have look like?
Did you ask around for any advice before ordering a DP? Did you read their description on the web site before ordering? Did you talk to anyone at GN1 about your setup before ordering? :eek:
dang it, looks like the first pic
Shoulda saw the recon comments coming:p. looks like im going to adapt and overcome the situation with an external setup now. While on that subject without searching any recommendations/how-to? At this point whats the simplest solution/steps to the problem at hand? thnxs for the replys
Simplest solution is get a internal wastegate DP, I don't know their return policy.
Otherwise you need to find someone who can fabricate, and spend more money on a external wastegate...Upside is you will have rock solid boost control from now on.
the gate is cut off in this pic but you get the idea...
in the above pic... why do you have the boost control knob by thr radiator cover and not inside the car within easy reach?
