Freddie's Buick
Hell No! I'm not a junior
- Jan 3, 2002
I've just received a donated timing cover and it looks like the engine this came off of suffered a catastrophic break-down.
After a little bit of cleaning I found chunks of metal embedded into the port openings, (wow)!
I tapped out the metal pieces and then fitted my OEM gears to check how bad were the clearances, (I had these gears stored since 2000 and installed some Kenne Bell gears).
To my surprise the clearances are all in top order.
.002 end clearance. 002 side clearance.
I sized up and extra KB oil adapter gasket which came out to .006.
In the foreground you can see a new adapter I bought from Silver Seal $22.50, (decent price I think).
If this is a foreign made product I have to say that the quality is top notch. No flash and smooth port openings. I think this company is very good.
I will continue this thread as I slowly attempt to recondition this terrorized timing cover. I may even go as far as installing it based on the numbers I've got for in clearances.
You guys think I've lost my mind yet?.....Lol!!:biggrin:
