Are these cars known to have bad panel gaps? I removed my passenger door to do some rust repair, and now I'm test fitting it to make sure it has decent gaps where I patched.... anyways it was a bit of a pain adjusting the door.
The door hinges are bolted on the car I never touched them, I removed the door by unbolting the door from the hinges.
What I'm adjusting is the door itself with the bolts loose, now it seems that you can only pull the top out or the bottom, no up and down movement? Or in and out(towards front of car, or towards rear).
I just want to make sure I'm trying to adjust it right.
This is the best I got it to be for now. I had to grind my patch down so I will have to reweld the bottom because I burned through the bend.....
Pictures:
See the top is wider than the bottom, and it was hard to make the door not hit the front fender(center horizontal body line).
Pictures:
