Dec 27, 2006 #1 M mybuick intercooled engines rule! Joined Jul 21, 2002 Messages 1,502 i would like to know how to remove the rivits with out breaking the glass on the window guide. heres a pic
Dec 27, 2006 #2 F forcefed3.8's Buckeye Bullet Joined May 26, 2002 Messages 3,845 Very Carefully grind the heads off with a cut off wheel. The rivets are aluminum, so they cut like butter.
Dec 30, 2006 #3 C cruzn57 Still plays with cars! Joined Apr 18, 2002 Messages 4,877 important!!!!! grind a little, and let it cool, if the rivet gets to hot it'll crack the window, but being aluminum, should cut quickly,
Dec 31, 2006 #4 T turbo39151 anycoloraslongasitsblack Joined Nov 7, 2002 Messages 4,460 You can tap on the head of the rivet lightly with a small punch. (of course the glass must be supported propertly.) Then drill the rivet with a couple of metal bits... It's a pain but is doable...
