Mar 7, 2009 #1 R rb68rr Active Member Joined May 25, 2001 Messages 1,534 How do you remove the top pin without removing the entire hinge? Looks like a lip on top of the pin??? Thanks, R.B.
Mar 7, 2009 #3 R rb68rr Active Member Joined May 25, 2001 Messages 1,534 Really! Just cut it in half?
Mar 7, 2009 #4 M mybuick intercooled engines rule! Joined Jul 21, 2002 Messages 1,502 i used big bolt cutters and had a friend hold the door so it dont fall
Mar 7, 2009 #5 A A2000RICH Well-Known Member Joined Mar 31, 2004 Messages 1,035 rb68rr said: How do you remove the top pin without removing the entire hinge? Looks like a lip on top of the pin??? Thanks, R.B. Click to expand... cut it in half with a dremel tool, a die grinder or a saw of some sort-----pull the upper half out the top and the lower out the bottom-------some advice-----cut it with minimum burrs or else it will be difficult to remove..........RC
