Selling my double pumper fuel pump kit:Come with 2 pumps that I bought 3 years ago from full throttle that are rated for 500 HP each. The 2 pumps have a maximum of 600 miles on them and worked great when I took them off the car.
Adjustable hub switch that is boost activated.
Sending unit with all the wires needed with relay to make this kit a complete bolt on.
The 2 fuel socks are in good shape and clean and could be reused without a problem.
Only bad thing is that the fuel gauge part had broken off and I tie rapped it to get it to work. It still works but is a little off. Have to be very careful when you put it in and out of the tank not to get to hook up anywhere.
A part from that everything worked great.
I want 325$ for it.
Thanks,
Marco
