Doug Nash Overdrive Unit
incharge
OK I picked up a DOUG NASH OVERDRIVE UNIT for a turbo 400 transmission that was in storage for the past 9 years this was bought brand new and never installed I was going to see if it would fit in my GN and go with a turbo 400 trans. but now I am thinking of selling it . What do you guys think, WILL it fit 1st?? and what is it worth to someone?? I would think this would be the ultimate set up for the gn a super strong turbo 400 with OD for way less than a built 200R4. jUST TRYING TO GET SOME INPUT.
well the unit is so big i dont think it will fit in our car's. mostly i have seen them in motor home's and pick up's. they were nice set up's but you can no longer get parts as they went out of business years ago.
From the size of that unit, it looks perfect for a bus or cube van. Its way to tall to fit in a buick unless you want to cut driveshaft tunnel out. The gear vendors unit is 7.25" tall and is already a real tight fit! YOur unit looks very tall, how high is it?
Does any body have a use for the overdrive unit , good for a 4x4 truck or hot rod project ??
