Drag Radials
24-25 psi on a stock motor and a TE-44 Turbo...enough? That coyote is going to live up to its name and eat your Buick alive. Order the new MT DR Pro. The 235 can do it and being that you don't trap over 115 you surely don't need a 28" tall tire. The 255/60 is OK but I'd use the 235 about 16 psi in the tires and a E-brake launch. Spike the Punch! Add 5 gallons of 110oct to your quarter tank of 93. The less 93 the better. Then use 25* of timing in 1&2 and 22* in 3rd. Set the ally to 7 and add 10% fuel to WOT fuel and pull 12% in first gear. Boost should be at 30-32 psi. Launch with about 12-14 psi and don't let the 02 reading fall under 780. Do that and you win!
I can sense you becoming nervous already and doubt you will take any of my advice. So... I'd like to place $20 on the Ford for the win light.
Haha. I'm used to running my vette or busa on the track. This GN is different with boost. But I'll get used to it. As long as them M/T 's Hook. Done deal. I'll be posting about the race next Friday night. Plus it should be around 70 deg. That will be good.
I fit 325/50/15 MT under the rear of my car. I have the gnx fender flares on it also though. Without those they would stick outside the car. 3 3/4 backspacing on a 10" wheel. Looks sick from behind the car. Haven't taken to track as bearings in motor went out.
This is only picture I have of them right now. Little over kill but I bought tires an wheels dirt cheap an they were all brand new :-D honestly didn't think they would fit. Hope this helps
