Mar 21, 2006 #1 G grkgn Member Joined Mar 26, 2002 Messages 148 Is it normal for these cars to vibrate at 90 mph when you accelerate lightly on the highway? Does it have something to do with a rough idle?
Mar 22, 2006 #2 H hiballin Bettie is the boss Joined Jan 10, 2006 Messages 129 no, not normal. many things can cause vibrations but i would first suspect tires/wheels. check for flat spots on tires, tires not balanced, or bent rims. if that stuff checks out then you need to start looking into the driveline.
