Dw300 wiring
MauDeuce50
Need Rehab for Boost Addiction
Can someone tell me how to wire a dw300 on stock hangar and wiring? Also have racetronix G7 wiring if I need it. Stock is on the left, dw300 on the right. If I just just switched the negative and positive what would I do with the other wires hanging out?
Neither of those connectors are with the DW pumps I sell which are for the turbo Buick application?
If the connector with 2 wires fits into the DW pump you only need the 2 wires, red power/black ground, spliced into the hanger wiring.
The connector fits so I can just switch the polarity and be fine then?
Some of the Racetronix wiring is ass-backwards, just be sure the DW wiring is red to power, black to ground.
