Well I finally got to put it on the dyno......I made 2 pulls within 3 minutes of each other. First pull was with the T92 and 20psi and the second pull was with the T108. Peak #'s are 310hp and 435ft-lb.! Not too bad for a slightly modd'd Gn. The T108 chip actually was about 20hp higher below 3000rpm but was basically the same all the way up to 5000. The car had a FLAT 300hp curve from like 2600 all the way up to 5000! It's right on the money as far as the A/F, it was 12.5/1 all the way up to 5000 as well. Now the fun begins with the new additions
