SignUp Now!With the stock pump hanger and fittings you would just connect your new return line where the old return line connected. I think this is what you are asking? This should flow plenty.Question on replacing fuel lines. I pulled the tank last night and installed the new DW300 pump. I am running new supply and return lines in 6an braided hose. I was only going to replace the return only but found the supply line crushed when I pulled the engine, removed the accessories and got to those hard lines. Those replacement hard lines for front of the engine's is not cheap, so just decided to replace the entire line to the pump as well. Running 2 lines only cost twice as much right!?!
Here's the question. You want to replace the return line all the way back to the pump. Do you then reconnect to the smaller hard line fitting on the top of the gas tank? Seems like that would re-restrict the line flow? Of course you would have more volume in the line as a whole. Or do you modify the hard line connection at the pump to be accept a larger return line?? How would you do this?
Not off the top of my head. It should be close to 1/4" NPT but I am not sure. Someone on here knows. I think turbofabricator welds this fitting on. He has some good info on here if you can find it with the search function.Brian, Thanks that what I am looking for. Do you happen to remember the size of the NPT?
