SignUp Now!It was 2.459/gallon. I don't care if it was $5/gallon. I'd pay it in a second if I knew i was getting 80% or better crystal clear E85. Those who are running e85 aren't doing it for economy reasons. They are doing it because of the benefits it offers. I've personally never tuned an e85 car that made less power than any other fuel. I've seen a couple engines make more on a race gasoline but they were purpose built class racers and I'd be $$$ if they ran higher percentages of ethanol or methanol than 85% they would be able to make more power than gasWhat were they charging up there?
The only place near me, 25 minutes away, has jacked up their prices to around $260 a gallon cause “we’re the only ones around”
D
Bison, is E85's Octane & good cooling enough to run without an IC for a relatively stock engine ?It was 2.459/gallon. I don't care if it was $5/gallon. I'd pay it in a second if I knew i was getting 80% or better crystal clear E85. Those who are running e85 aren't doing it for economy reasons. They are doing it because of the benefits it offers. I've personally never tuned an e85 car that made less power than any other fuel. I've seen a couple engines make more on a race gasoline but they were purpose built class racers and I'd be $$$ if they ran higher percentages of ethanol or methanol than 85% they would be able to make more power than gas
Is E85's Octane & good cooling enough to run without an IC for a relatively stock engine ?
Thanks Raf . i'm just lazy ( most of ) sometimes
NP...it seems like IAT's go pretty high without the IC...above 200 degrees, but only means so much because the cooling aspect of the E85 only happens in the chamber. I would think some meth with the E85 would perform pretty dang well without an IC, but I'm no guru.Is E85's Octane & good cooling enough to run without an IC for a relatively stock engine ?
