I have decided I'm going to quit toying with E85 and go ahead and fully convert. After having discovered that my fuel pump is "not keeping up" with fuel demand, I just bought a Racetronix double pumper with Walbros, the improved grounds, a 7PSI Hobbs switch, and AN fittings on the sender (Just in case).
I'm hoping I haven't put the cart before the horse so to speak. I'm sure I will get many opinions that I need bigger injectors. At this point, I'm pretty sure I DON't need them based on the level of "stock-ness" that my powertrain is. I know that eventually, I will be upgrading to about 120's or so (maybe bigger), a WB02, Powerlogger, and possibly a modified ECM. My question is this:
In the meantime, until I get all the stuff listed above, should I be OK with the 60's, a TT E85 chip, and the new pumps? I would prefer to go ahead with the WB, PL, and bigger injectors along with the new chip, but I'm really afraid my wife will have an aneurism if I buy all that crap!! I just bought $700 worth of fuel pump, and I don't even care to admit how much on the new CCW's and tires!!! I have a couple of concerns however.
First, I'm thinking that the pumps may overwhelm my stock fuel system. I have stock lines, and I bought a 7PSI hobbs thinking that I needed the second pump to kick in sooner with E85. I'm sure that's probably true, but it is probably true "later on" when my motor has more demand for fuel volume. What are the chances that these two 255lph pumps will kick on at 8PSI and "over-volume" my fuel delivery system?
Second, without PL, how will I know if I'm maxing out my injectors? I've read on TurboTweak's website that Eric feels that 6o's are perfectly do-able with E85, and with my "close to stock" combo, I tend to agree with him for the short term. Another question that goes hand-in-hand with this is "How does running E85 affect O2 millivolt readings on the scanmaster"? Do I need to keep O2's where they normally read with pump gas, or aim for higher or lower O2 readings with E85?
I know, I know... What I SHOULD do is go ahead and get the WB, PL, chip, and injectors, but like I said, my wife would probably shoot me if I did (with the new Glock 26 I just won in a raffle!!). I'm not worried about having to buy a chip & injectors later; I can always pass the ones that I have off as "failed" later on if I need to. I just bought the 60's and I know I can sell them (and the chip) here because they work fine. I'm really looking for opinions and advise from the E85 gurus on whether I should be OK with 60's, stock turbo, plenty of fuel pump, and no PL or WB for a little while.
Thanks for any and ALL input!!
