E85 Flex fuel/Filter location
87national55
199
35
28
Socal
Gents, getting ready to run my lines and trying to get ideas on where to mount the flex fuel and filter. To those running this, can you post some photos? I would also love some feedback on where to mount this. I can provide photos of frame if needed.
Thanks in advance
Note: I have boxed in my frame, I will be running #8 PTFE
Boost231
What's An Intercooler
Staff member
May 26, 2001
14,798
856
113
35
SoCal
www.arizonagn.com
Depending on lines etc either mount the sensor under drivers seat or near the junction block next to the tank
87national55
199
35
28
Socal
Forgot to mention I will be running lines inside frame on driver side
Boost231
Staff member
May 26, 2001
14,798
856
113
35
SoCal
www.arizonagn.com
If stock lines I like by the tank. After market lines I like under the drivers seat. In the return of course
87national55
199
35
28
Socal
Thanks, I will be running aftermarket -8an ptfe. Originally I was thinking mounting the sensor or filter (maybe both of possible) where the proportioning valve goes since I will no longer be using stock
dank GN
BlackArts Automotive (661)993-8277
Jan 11, 2009
3,758
471
83
SoCal the high desert
I am trying to find a picture of how I mounted mine . I mounted it in line with my -6an return line . I mounted right under the drivers side door where I made alil bracket to attach the sensor . It’s funny my 2 -6 Teflon fittings cost more then the flex fuel sensor .
87national55
199
35
28
Socal
If you want to mount it like above we sell a bracket that works with that flex sensor.
You have a photo of the bracket? Anyway it can go where the proportioning valve goes?
87national55
199
35
28
Socal
Do you go female or male at the ends? I’m thinking female ends avoid having extra fittings and possible leak.
