SignUp Now!No.Im planning to run E85 in my '85 GN with ported iron heads and Work 5857 turbo and ported intake, 3" DP, 3" single shot exhaust and of course all other supporting mods-
Will the stock fuel lines be good enough for the increase in required fuel volume?
I'm more concerned with the size of the lines- are stock lines fat enough?No.
PTFE is the most logical choice.
Not cheap, but very reliable.
E85 requires 30% more flow.I'm more concerned with the size of the lines- are stock lines fat enough?
You should look into putting alky injection on the carIm planning to run E85 in my '85 GN with ported iron heads and Work 5857 turbo and ported intake, 3" DP, 3" single shot exhaust and of course all other supporting mods-
I don’t disagree. That being said, I did my homework for my situation.Hope all realize that these cars are very old now and trying to introduce alcohol based fuels han speed up the failure
Just some food for thoughtI don’t disagree. That being said, I did my homework for my situation.
I ran ALKY for a bit. Didn’t hate it, didn’t love it. More wiring, underhood plumbing, pump rebuilds, yada yada.
For me, we have E85 at the pumps locally(I have a tester to check the content). So that means not having to worry about pumps, finding methanol, & the other things ALKY entails.
I planned accordingly for a fuel pump that is sized correctly, works with E85, & I’ll change it out every few years. I switched over to -6 & -8 lines. Kept the stock lines & capped them. Injectors are sized to work with E85 & my build.
A bit more work upfront sure but now I can go & just get 85 at the pump & go about my business. No worries about constantly filling up ALKY, pumps, etc. Not to mention gotta love the octane content of 85 & its knock resistance.
That’s just my preference though.
>50 #s of boost will do that!But I also run Alkycontrol on top of that.
Stop>50 #s of boost will do that!![]()
With a 58/57 turbo you need to go through all of it. Pump, lines, injectors for sure. That turbo will flow 550 to 600 all day long according to Reed so do it right.I ran e85 using stock lines with the Saginaw fittings removed. Vent & return were switched. Walbro 450 and 80lb injectors. I had no fuel issues running a Te44 for all it was worth. It isn’t the best way, but it can be done.
