E85 Injectors, 71HPQ, AFCO shocks, Weldon, Koni, Crane Ignition, more
re-evaluating
Can't even re-member
Precision 71HPQ 3 bolt turbo went 9.17 @148 with under 25lbs boost (controller failed had more in it) $1200
212 lb Siemens Deka injectors (6) or (8) your choice
120 lb low imp injectors (6) flowed NEW from Precision (SOLD)
Bosch142 lb Injectors part #280-412-912 used flowed by Richard Clark $350
AFCO rear stock location shock w/Big Gun valving less than 20 passes SOLD
Koni SPA1 adjustable drag shocks front $125
Koni SPA1 adjustable drag shocks rear $125
New Weldon 2025A fuel pump (been installed but not run) $650
HRparts XD suspension lower trailing arms $150
Metco spare tire well fuel cell set up for in tank pumps SOLD
Brand new Pat's converter TH400 $750
Crane HI6 ignition box and LX92 Coil (made 750 rear wheel HP with this) for use with distributor $200
6 plug wire heat shields $30
Stock style adjustable waste gate $30
3 bolt exhaust flange to build your own downpipe $40
RJC boost controler $35
New Caspers Injector harness $75
Brand new Hella Solid State Relays $25 each discount if you want several. These are great for Bump Box or any normal relay application.
Can deliver to BG next month if you wish.
Contact Dave at 6I8 322 3454 text is best way to reach me.
[ATACH=full]286882[/ATTACH]
how is the ride with the koni shocks?
I wouldn't recommend them on a daily driver but with a rear anti roll bar I never noticed any ill handling moments you can get from drag shocks. I think they drove well on the street but I knew I was driving a 9 second race car on the street, and drove it accordingly.
I'll take that metco cell
