turbo buicks
ESADAH!!!
- Jun 13, 2002
anyone know anything about this ethanol/gas mix GMs doin in their cars now?  i read that its 105 octane.
SignUp Now!Pablo said:yeah, go to wikipedia and look it up
its been around forever. You can make it in your garage if you want to.
Even the Model T was flex fuel, could run on ethanol or gas with the twist of a screwdriver.
also, in addition to the octane it runs much cooler since it has a higher latency of heat value than gasoline. It would be a dream to run in turbo regals and I would have done the conversion if the fuel was available here (it requires more fuel to reach stoichiometric so it would require a different chip to do it right)
ethanol is the ****, and I think an answer to our oil woes.
Pablo said:72firebird,
I think you are repeating the myths associated with e85, you should go look up some more info, the article on wikipedia is a good start. The argument about it having a negative energy balance has been disproven. The data used to come to that conclusion is from the 70s. Look at brazil, something like 85% of their transportation energy comes from pure ethanol, their ethanol production is so efficient that they have surplus energy that they sell to the state electric companies.
72firebird said:However E85 doesn't produce the same amount of energy per gallon as your everyday gasoline.
UNGN said:E85 has 60% of the BTU's/gallon of gasoline, so science says a car will NEVER get better mpg with E85 vs. gas, Automotive Company Marketing departments not withstanding.
I dont think youve thought about all the variables involved. Gasoline octane is much lower and has a much lower latency of heat. You can only run so much compression with a gas engine before it detonates, heat is a contributing factor with the gasoline so you should be able to run more compression than you would run even if you compared 105 octane regular gasoline compared to alcohol because you arent heating the chamber as much. More compression = more torque, as a rule of thumb ive seen for every point you increase the compression you increase the power 4% with gasoline engines. I've seen references to engines running ethanol all the way up to 19:1 compression ratios, lets say its a really efficient gas engine and can run 11:1 cr, thats still 8 points higher, 8x 4% is 32% more power than what an ethanol engine would normally run at 11:1 cr and im certain that the ffv's right now dont have a 32% difference in power output as they stand from running gas to e85.
In fact, your argument has allready been disproven, saab manufactures a turbocharged FFV that makes more mpg than when it runs gasoline. It specifically takes advantage of the higher octane/latency of heat that alcohol has.
Octane isnt just for WOT, octane is all the time, if you increase the compression ratio of an engine you are going to make more power ALL of the time, not just at wot. This translates into using less throttle to accomplish the same amount of work. So instead of using 1 volt of tps to get to work you can get away with lets say .8 if you optimized the engine to run ethanol
OR you could reduce the displacement of the engine, make the same power, and be lighter.
The Problem with E85 is what I will refer to as the "Julio Problem". Do you NEED 105 octane to drive to work? Sure you do, but only for about 20-30 seconds total. The rest of the time 87 octane will do fine.
Like I said above, octane is for all the time. Thats even more proof I think.. the fact that t/rs can generate so much more power using alky injection using only a small amount of alcohol should make it obvious about the potential it has in just using it as your primary fuel. If you can make more power then you dont have to use as much throttle or displacement to do the same amount of work.
E85 injection is and WILL ALWAYS BE a much more efficient means of using E85. Because E85 costs more to make than it is sold for (and the difference is subsidised), the Price of E85 will be based on the price of Gasoline.
By e85 injection, do you mean like auxiliary injection like an alky kit? because I dont know and havent read of anyone using 85 like that so I dont know where you get your data. E85 is still in its infancy, and there is not a vehicle on the road that i know of that is designed specifically to run e85 only. I'd also like to see how you come up with it costing more to make than what its sold for.. where is the profit incentive if that is the case? Gasoline may be a factor in the price of ethanol but there are many factors.
E85 WILL NEVER BE 60% of the price of Gasoline, so Gasoline powered vehicles (or gasoline powered with on demand E85 injection) will always be cheaper to run than straight E85.
How do you know this? we havent even begun to touch upon our capabilities when it comes to producing this stuff. You remind me of those guys throughout history that make some bold prediction like a car never breaking 125 mph in the quarter mile because its impossible only to have it resoundingly disproven. Ethanol may not be more easily produced than gasoline today but there is great potential for its production efficiency to increase. If we are to believe the doomsdayers, gasoline can easily be many magnitudes more expensive than ethanol. All it takes is a cartel like opec deciding to increase the scarcity, or war, or other political changes to make the same thing occur. This in addition to the fact that many people believe oil is a fossil fuel ensures that it WILL be more expensive than ethanol at some point since it is not renewable. Eventually it will be so scarce that the alternatives will be cheaper. Ethanol does not REQUIRE any gasoline to produce, ask the amish how they grow corn.
Lets also not forget the hidden costs of gasoline, the price you pay not at the pump but in your taxes, from using military intervention and political wrangling to ensure our supply from foreign lands, to an expensive environmental program and beaureacracy to clean up all the messes burning gasoline causes.
The sooner car makers recognize this, the brighter the future E85 will have. As it is now, they are Selling Sizzle and when the steak shows up cold and tough, people are going swear the stuff off for good (and tell their friends)
I think with whats out there and coming to the market people are going to disagree with you, in fact its allready happening. There wouldnt be this huge interest in ethanol if it were crap. The price wouldnt be increasing if demand was sagging, its increasing. Look at the ethanol production numbers from 1980 to today, its a HUGE increase in production
They only have one chance to make a good impression and I'm afraid the impression they are going to make is a bad one.
Its allready made a good impression, everyone I have talked to that knows about it, or can understand what it means has an extremely favorable impression of e85, the fact that we dont have to get our fuel from foreign nations, it burns cleaner, and offers better performance is hard to not be excited about
UNGN said:My experience with ethanol goes back 20 years. Being from Nebraska, I happily filled up with "Gasohol" back in the 80's because it was cheaper and higher octane. When I got older, I actually started measuring my gas mileage. The "Cheaper" gasohol was actually costing me more.
I became a "non believer".
The current crop of "flex fueled vehicles" will have the same effect on a new generation of people.
E85 is 95% marketing hype and 5% reality.
You can believe the marketing hype all you want. 5 to 10 years from now, you will say, "UNGN was right."
All you are saying about compression ratios and turbochargers and designing a vehicle to run on E85 from scratch may be true (only time will tell), but those aren't "flex fuel vehicles".
Flex fuel vehicles will KILL E85 from the bad taste it leaves in consumers mouths when they fill up their taurus with E85 and get 14 mpg.
