GNVYUS 1
- Dec 15, 2002
Firebird and UNGN have some great points.
Firebird is right on how they have not yet maxed out the compression ratio to use the E85. And in not doing so are losing gas mileage because of it.
Think of it, you can probably run 15:1 with E85 which would need less rpm to move your car 45mph. Instead, we have the 9:1 flexible fuel cars that are not making use of the 105 octane E85 due to the majority of gas buyers using 87 octane when they switch over to gas.
But, the fact that E85 has 40% less BTU's, is still an issue. When you do kick up the compression to say 15:1, that means you are going to need even more E85 than those cars are using now. The power will go up, but so will the E85 comsumption. It might be a wash on the gas mileage gain when you do kick up the compression, I doubt it, but I am not an engineer.
Around here there are a lot of E85 stations, and the fuel was around $2.15 last I checked. But you need 40% more, which means that it is really $3.01.
I get 110 unleaded for $3.99 here.
