Originally posted by REDS HOT AIR
If more people gave them props for making cranks for our engines instead of all the complaints maybe eagle would produce more of them
basically If your building a motor thats in need of a steel crank you should be able to handle a crank install.. no need to complain to the manufacture
If you cant handle installing an aftermarket crank then You should get someone else to build it
this is directed toward everyone not just anyone in perticular
some of us would like to see eagle continue to make products for our engines
