Nocturnaloner
- Aug 24, 2005
So I took a gamble, and bought a 200-4r transmission on ebay. The seller claims it to be "suitable up to 500 horsepower and above". His feedback is good. If it's good to anything over 400hp, it should be more than adequate to my purpose.
Question: Given this laundry list of mods and features, what can I confirm or disprove without taking it in to a trans shop for a teardown?
(Translated from all-caps description, with numerous typos)
"Specially modified pump with fixed slide for high-RPM pressure increase
Pressure regulator full-time lube modification
Large boost valve
10 vane pump
Teflon pump bushing fixed in place, and enlarged drain back passage to prevent front seal blowout
Third gear direct 8 relined (redlined?) frictions (drum modified to use both chambers for third apply)
Forward clutch, 5 frictions
Fourth Clutch, 2 relined (redlined?) frictions
Low reverse clutch, 7 Alomatic frictions
Kevlar wide band (20% wider than stock)
Fairbanks Super servo
Hardened sun shell
Shift kit - all valve bodies upgraded to exceed GN (GM?) specs
New seals and rings.
The planetaries are modified for additional lube"
Large boost valve
10 vane pump
Hardened sun shell
