Little6pack
- Jun 2, 2002
My 1996 v-6 OLDS has ODB2 ECM port.
The ECM throws the code for #6 cylinder to go off ....I have changed the #6 spark plug, new wires, & coil pack.
I have figured out the the trans has a funky shift point which causes the code to set off the #6 cylinder to light up.
My question is can you drive any vehicle with this tool attached to your ADL port permenatly with out causing issues? & to allow it from throwing the code over & over
