Brian Felts
- May 19, 2007
Ok I had posted earlier about the code 42 now The codes are changing each time I scan the car. When I do a realtime scan at times it will give me "vehicle not responding" then at times it will scan but all of the sensor values stay the same.............O2...tps...intake temp.  I am using a auto X Ray
The car also idles high then surges badly
Do you think I have a bad ECM.
Thank you for all of your opinions!
Brian Felts
Brian Felts
