ecm upgrade to 86/87
luisturbog
UNDERDOG HOT AIR !!!!!!!
what firing order do i use one i do the upgrade? from 84/85 to 86/87 should i just go by the numbers on the coil?
when you go to the 87 ecm the firing order is the same just wire it up like normal.
figured it out
well i figured out the difference; wires go on the opposite side. You switch all wires from one side to the other. Next upgrade will be my ecm. Hope everything is straight forward, I hate when I find out I have to buy a few more things for the upgrade!
ecm is straight forward. just get a IAT sensor put it by the air filter get a chip and i changed out the MAF to a 87 and your good to go.
