Lil Truck
I spend to much time here....
- Sep 26, 2002
I have had this occur 3 times now since I installed a new motor and trans. Log 1 is a clean run and Log 2 is 5 minutes later when the motor looses all power for a fraction of a second. I lift immediately the motor does not die ??? I am thinking the new crank sensor is possibly the problem, looking for any input on this situation.
ECU, wiring harness and most of the sensors are from the previous build with no problems. New sensors, crank, cam, oil pressure, knock sensor.
42k miles on the rest of the car and parts. The ECU is modded but has run fine for 3 years.
Every sensor in the log drops to 0 except the WBO2 that is not controlled by the ECU
Motor and trans now has about 800 miles with no problems........except this
I have gone through every connection and ground, everything is clean and solid. Dry desert conditions and over a month since the last car wash.
Steve
Steve
