- Aug 1, 2003
the o2s arent different driving so long as egt temps at sensor are above 600*F which you should have driving around , eric runs open loop idle so the low temps and low response sensor really doesnt create any issues , if your exhaust is still restricted (cat converter, poor catback muffler system ) then the temps might stay up at op temp as they do pre turbo , if you had a closed loop idle chip then you might have issues and need to go with a heated sensor as most factory downstream sensors on obd11 cars,
the sensor mounted after turbo is just better able to show the true O2 (still narrowband but should show higher) at WOT under higher boost , no and low boost usually doesnt affect sensors as much as the high egts and pressure do
doesnt matter , you really shouldnt tune a car based on numbers from a sensor , rather tune the car for performance then look at what those sensor show and thats your target for your car , trying in future runs to not stray to far from those #s or looking for deviatiations from those sensors to spot problems early before they get worse, just as you would do with your oil pressure and water temp gauges
