JeffGordon
- Sep 2, 2010
I purchased a Red Armstrong XP pump and hotwire kit which were both installed (by a mechanic) about a month ago. The other night I took it out and it would not start at the gas station. I couldn't hear the fuel pump whining at all. So I wiggled around on the Hotwire relay and the pump turned on again. (Thinking Loose Wire)
I turned it off again and it wouldn't restart. So, I wiggled the wires (Near the hotwire relay) again and it restarted. Hmmm.
Now, it won't restart at all. No fuel pump whine or anything. I don't think that it's the hotwire kit at all. The FP fuse is good. The factory wires are hot.Everything is working up to the orange connector (to the fuel pump). I also changed the fuel pump relay under the hood. I am thinking that it could be a ground or something loose up by the fuel pump. I had the pump installed so I am not really sure what the connections look like up there. I would drop the tank but it's half full of gas and wanted to weigh my options on here first.:biggrin:
Any ideas? It's driving me nuts and any input would be greatly appreciated.
