85begalttype
just a v6
- Oct 22, 2008
i have a hotair motor with stock turbo. i want to simplify the ugly vacuum routing by cleaning things up. since im not interested in going over stock psi of boost, can i just remove the wastegate solenoid by removing the vaccuum T and going straight from the compressor to the wastegate then back to the vaccuum block on the throttle body. If i ever needed to increase the boost, i would just shorten the rod. Would this work? would i need a vacuum restrictor in the line somewhere, since i think the wastegate solenoid has one ?
