My 3.8 turbo emblem broke on my trunk and I had to pull it off. How the heck do I get the black adhesive off the trunk? I have tried brake cleaner and WD-40. It is really thick and soft. No dirty thoughts now! Any thoughts?
Go to your local automotive paint store and ask them for adhesive remover. Thats what we always used at the bodyshop i used to work at. I can't rembember if it was a PPG product or a 3M product but I do rembember that it was in a red and white can. It worked really good
3m makes a wheel for removing adhesive that works really good. if you have any friends that work at a body shop they might be able to do it for you, it only takes a few seconds to do something that small.
Got the junk off but it took a bit. It was really gummed up so I had to let it soak for a bit and scrape it with my fingernail and then I had to soak it again then it came off pretty easy. I did use the 3M stuff.
