Emblems, knock gauge, cam sensor/tool, and more!
Update #3- more stuff!! See Below! I have pics for all.
Cleaning the garage- parts a plenty! Let me know what you need......it may be hiding in the shed.....
NEW/NOS
1) 2 NOS "3.8 SFI TURBO" emblems (w/blue backing tape) $30 each + ship
2) 1 B&M Unimatic automatic floor shifter $75 shipped
3) 1 cam sensor assembly $94 shipped SOLD
4) Casper's cam sensor tool SOLD
5) NOS 1987 gray "T" horn button assembly with mounting screws SOLD
6) Small K&N filter for passenger valve cover SOLD
7) steel OE spec timing set (gears and chain) $30 shipped
8) Window rattle elimination kit $30 shipped SOLD
9) Edelbrock rear tubular braces (w/ instructions, no hardware) $60 shipped SOLD
USED
10) 2 good/very good "3.8 SFI TURBO" emblems SOLD
11) 1987 TR/GN power steering reservoir with bracket $40 shipped
12) Black on black Casper's knock gauge with mount and instructions $65 shipped SOLD
13) turbo up-pipe painted (no holes) $15 shipped
14) 2 good stock 86/87 ECMs with calpak chips $60 each shipped
15) coilpack/ignition module assembly with wires and mounting bracket $125 shipped
16) 2 passenger side relay assemblies with ESC/MAP/relays $25 each shipped 1 available
17) 2 IC fans with brackets- 1 painted black, 1 stock $15 each shipped both sold
18) factory header/crossover assembly- no cracks- with EGT probe installed $285 shipped
19) stock rear lower control arms with factory swaybar $50 + shipping
20) 1987 GN instrument panel assembly- 80k miles SOLD
21) Instrument panel surround- good driver quality $40 shipped.
22) 2 factory cooling fans- 1 stock, 1 modded (high speed operation only) $40 each + shipping
23) 87 GN dash w/ducts and glovebox- foam is soft, no cracks or tears in material. $200 + ship
24) ported 8445 heads- 1 needs to be welded - ask for more info
MORE STUFF!
25) boost solenoid w/ bleeder valve & hose $50 shipped
26) New autometer electrical oil pressure gauge w/o fitttings make offer
27) mounted mechanical gauge set (oil pressure/ water temp) w/fittings $50 shipped
28) 3" dump tube- needs to be welded in $60 shipped
29) 1987 Buick body service manual $17 shipped.
30) 1987 service manuals books 1 and 2- used (and heavy). $100 shipped
31) Doghouse gasket $5 shipped
32) new 200-R4 shifter detent plate $20 shipped
33) 2 new rear drums and 2 new rear wheel cylinders $50 shipped
there's a bunch more out there to go thru yet...offers?
