sixftseven
SIXFTSEVEN
- Dec 1, 2007
When I'm sitting idling and rev about 3000rpm the engine cuts completely out. I can floor the throttle and it cuts completely out to the point of almost cutting off. I've changed plugs, wire, ignition module and coil with no change. Below 2900rpms everything is fine. Any suggestions will be greatly appreciated. Thanks in advance..
