Hey Guys-Just bought a 87 GN with Main or Rod Knock. The engine was built in the late 90s it has been balanced and blueprinted, kenne bell cam, TA 49 turbo, ported irons, Art Carr 9" 3000 stall non lockup converter and 3.90 rear gears. That's all I currently know.
I purchased a 5500mi rebuilt long block off a board member. Factory build with the exception of main, head studs and ARP rod bolts.
The plan is to swap over the ported irons, possibly cam and lifters and perform the earl brown oil pump mods.
Here are my questions.
1. For some reason they put the shorter main studs on the middle two caps on the left side... I plan to swap them to the rear caps where I feel they should be. Could me moving these cause any potential issues? I don't think so as the block registers should be aligning the caps not the studs.
2. Would you guys swap over the cam is it looks good and I take apart the lifters and clean them?
3. Another option would be to leave the stock cam and install some 1.65 roller rockers or purchase another cam?
4. Would the stock cam with 1.65 rockers be enough to utilize the ported irons.
Keep in mind that the car is equipped with an Art Carr 9" 3000 stall non lockup converter and 3.90 rear gears.
Goals are to have a fun street car that runs 10.99 or has 600HP witch ever comes first. On E85.
