engine build up have questions
turbotoyz
under reconstruction!
i am fixing to gather all the parts to put my engine back together,
will the current cam 210/205 put me in the lower 11.20's with a te62? another question i only have a 2800 stall is this enough to run the te62? i have 009 injector with mass air translator with extender chip. what elese besides the stuff in my signature do i need to get that low? thanks in advance.
turbotoyz
You'll come up short on the stall. The cam should be fine. Are you runing ported heads? The injectors may start to become a weak link around those times. Might want to think about more fuel pump like a 340 or doubles.
