Engine build
Blacky
Drive it like you stole it
Pressure tested. Good block done 20 over. Installed center main caps . Line hone and balanced, stock mag crank. Front oil galleys tapped. Comes with cam bearings, pistons and rods of measured. Should be the complete engine with nuts and bolts minus the cam as I never got that far, unless you want the original Stock Cam. Needs to be put together Cleveland Ohio 5000.00 work done by victory engine. No heads either unless you want the stock ones.
If you are selling a complete short block I would suggest you put some pictures of the block in the ad. No one will bite on a piece of paper to buy for $5000. Just a suggestion.
Thanks for the help and when my son gets home I'll have him unpackage the block as it is all oiled up and I'll get some pics
Here you go Reggie. I have my son break his :) back to get some pictures that would be very useful like you said. Thank you Reggie. Anybody else needs any other pics or info, let me know and I'll try to accommodate.
Here is more detailed information
