Just below the fuel pressure regulator there is a sensor or switch that is positioned vertically. Is this the Coolant Temp Sensor or the Engine Coolant Temp Fan Control? I was working on my car last night and this part was loose. I took a closer look and it was broken. It may just be the pigtail broken. I need to buy a replacement but I don't know what to order.
I have another question- My car has been running between 1200 and 1500 rpms at idle. The O2 is running between 850 and 900. Could this be a result of this broken part? Thanks for your help.
