Drewster
Wish I Had A Clone. AKA Andrew Youlio
- May 31, 2001
I can't believe that these got by me prior to final block clean but I'm glad I caught them before final assembly.
These are nuggets of stock block casting sand and metal stuck up in the underside of block. It made it through 2 shop block cleanings and my hand cleaning before final assembly.
These may have stayed put, but a couple of taps with a chisel and they popped right off whole. There was another smaller one on top of the rear main seal casting that only needed a screwdriver prod to pop off.
So glad I found them and removed. May have been something similar that caused the demise of the original stock assembly.
The experienced may have seen this before, so posting for the rookies. ....Be aware!
Drewster on Tapatalk
