Ok so my 87 has been acting weird lately. I just had about a month and a half worth of problems all because of my crank signal sensor (see my previous posts for more info). Anyway that is fixed turned out to be a bad pin in the connector and now the car runs great except for one thing. After I drove it for about an hour the other day it started to run rough and died. So I started it and it fired right up but when I gave it some throttle it started to bog down and begun to die again. So I nursed it home and parked it. About 3 hours later it started right up and drove perfectly no problems for the half hour that I drove it. Than today I drove it again and after about 25 mins it died it. This time it was a little harder to start but I nursed it back again. 10 mins later started right up and ran like a champ. I have a newer walbro 340 fuel pump in the tank and I have about 20-25 psi oil press hot, 32 psi fuel pressure, 164 engine temp. What is going on? Any ideas?
