So I made a few chip adjustments to turn off wot tracking in my TT 6.1 chip and now the car does not want to run. It will barely run and idles very low and IAC is showing 140, everything else on the scanmaster looks normal. I adjusted parameters 1 and 2 from 108 to 99 because I'm not sure that my wideband is working properly. So after making the adjustment it won't start, I unplug the orange ecm wire to reset the chip, still wont start. After enough cranking it will barely run, then die. Pulled the IAC out and unplugged it, definitely looks like it's maxed out.
Did my IAC just quit on me? Weird coincidence? It's a cheap one from autozone I put in last year in a hurry.
